Reliance overhaul kit piston orientation
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: Reliance overhaul kit piston orientation
    Posted: 11 Mar 2019 at 9:06pm
I have a Reliance overhaul kit for the CA. The pistons have a notch in them, which way does the notch go? Also, the top ring isn't marked, so it must go either way? #2 and #3 rings have a dot on them.
Thanks in advance
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 9:27pm
rule of thumb is notch to front....your experience may vary...if they have offset wrist pins,it matters.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2019 at 11:46am
Contact the company or check their web site (Tech Tips, FAQ and also a Contact us info page)
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2019 at 4:10pm
O.K., I just got off the phone with Reliance. The top ring, being square cut, goes either way. The notch in the piston goes toward the front. I already had the rings on and the pistons assembled to the rods, but I thought I better make darn sure before I put them in, other wise it would drive me nuts wondering about it.
I thought it was to the front, but I did a Briggs awhile back, and the notch went toward the flywheel. That got the second guessing started....
I will say Reliance has fast, helpful people.
Edited by littlemarv - 12 Mar 2019 at 4:12pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2019 at 9:30pm
I would not want a top ring with out a inside champfer.      MACK
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2019 at 11:00am
Just a reminder, that the two pistons are assembled with the rods one way and the other two the opposite way, so the arrows are the same way after in the sleeves, because of the off set rods.
