Rehash. WC/WD oil filter
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 12 minutes ago at 4:49pm
Originally posted by WF owner WF owner wrote:
If you decide that you want to experiment with making your homemade bypass filter, remember that years ago, several engine failures were caused by Wix filters that didn't do what they were supposed to do. It's your engine...
Yup.
The faulty Wix filters were made of paper and did not create enough resistance to flow which resulted in too much oil going through the filter and not enough oil to the engine.
So long as a homemade filter has at least as much resistance (back pressure) as the stock filter, there will be no damage to the engine. Even if the filter is completely blocked, there will still be adequate flow to the engine.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 27 minutes ago at 6:34pm
Originally posted by Alberta Phil Alberta Phil wrote:
I opened up an old AC flat top filter today and it looks like its tightly packed with cotton string. On top of that is a piece of metal screen, then the threaded cover with the slotted metal dished piece in it.
Thank you sir! That is very interesting.
Edited by wjohn - 4 hours 26 minutes ago at 6:35pm
