Regrinding camshaft for wd45
wrightk20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrightk20 Quote  Post ReplyReply Direct Link To This Post Topic: Regrinding camshaft for wd45
    Posted: 19 Apr 2012 at 10:41am
I'm in the process of getting parts lined up to build the motor for my wd. It will be build with a wd45 crankshaft. I'm not sure on the liner kit yet, whether to go with a d-17 liner kit or go with an original wd 45 kit. I'm thinking about sending in a camshaft to have reground. Have any of you done this, and has anyone had them grind one for a little more performance in mind? I'm just curious to hear thoughts on this matter. Thanks, Kevin.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 10:58am
Crane Cam is who I used. I gave them the piston size, stroke and the RPM,S I wanted to run.  I was happy with the results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrightk20 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 11:36am
Another question i have is if i get a performance cam grind would it be a good idea to do a little porting to the cylinder head and intake manifold?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 11:42am
That is something I do to all my heads even it I put the old cam back in. If you want to ask the most of your engines you need to make it as easy for them as possible. Making the air flow restrictions as slight as you can will  only help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrightk20 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 11:52am
Thanks dick. You wouldn't happen to have any pictures of some of your porting work do you?
BRYAN H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BRYAN H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 11:54am
BERRY CAM SERVICE
GOOD GUYS
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 12:04pm
Theres not much difference in the cam doctor grinds from one place to another . If a company is willing to listen to your build and not just go with a shelve cam doctor grind it may be worth doing . Especially if they can splatter the pattern.find someone who was grinding in the 50s era for four cylinders like minis ,mgs and such.
fastgsxr87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastgsxr87 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 11:20am
Call Bullet Cams and talk to Sonny.  (662)893-8022
Mat
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 12:15pm
Call Barney Taylor at 937-368-2447
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 1:54pm
You can look thru these pictures at the link and and see if there is something that will help.
I might have some other pictures in another place also.
