Regaining lost hyd prime 190
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: Regaining lost hyd prime 190
    Posted: 23 Sep 2016 at 10:42pm
How does one go about getting a 190 hyd pump to prime. The last one we brought has no hydraulics and came to us nearly empty of oil. Tractor was being used to mow steep hills when it quit so I figured I'd try that first.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 6:02am
Crack open discharge line?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 6:40am
Put air pressure in fill hole while it is running 1/2 throttle.     MACK
This page was generated in 0.350 seconds.
