Red Kote
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Topic: Red Kote
    Posted: 18 Feb 2011 at 9:05am
Has anyone used the Red Kote gas tank liner product? Results good or bad?  Any tips on application?
Thanks,
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 9:17am
Yes, we use it exclusivly as a gas tank sealer.  It is a good product and works very well.  We normally take the tank into the radiator shop and have it dipped and cleaned before using the Red Kote.  That of course removes the paint on the outside as well.  If you are just going to seal the tank without repainting it, it needs to be cleaned out well on the inside.  For that we use MEK (methyl ethyl keytone).  Gotta be careful with that though cause it will take the paint off if you get it on the finish.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 10:00am
I've used it in quite a few tanks with good results. Never had any come back with problems!!
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 2:49pm
Used it on a D12 tank.  Like the results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 3:35pm
Talk about weird. I was just going to ask the same question. I just now got back from taking the gas tank off the WC and I was curious about Red Kote's performance.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 3:39pm
Just got back from the hardware store with the MEK, I am going to give it a try this weekend. Thanks guys for the input.
Bull
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 4:54pm
Be careful with M E K  . Static elertric or synthatic rags  can set it on fire. Guy at work was wiping down machine with M E K  using a synthetic rag , caught on fire in his hands.
GT in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 7:16pm
Be careful!  Both M.E.K. and Red Kote are highly flammable and give off alot of fumes... No open flames and wait until warmer weather if you are heating your shop with a woodstove.
1955 WD45 we like to call Ruby
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 10:01pm
I have used Red Kote for several years and would not use anything else.I had used others in the past and the Red Kote is cheaper and better by far.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
This page was generated in 0.445 seconds.
