Red Carburetor Washer/Gasket Material?
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Red Carburetor Washer/Gasket Material?
    Posted: 02 Apr 2024 at 6:27pm
Anybody know what the red gasket material is that most carburetor sealing washers are made out of? I'd like to buy a sheet of it. I always end up needing to make some random size that either isn't included in the kit, or I only need that washer as the rest of the carb parts are reusable.
I can find a lot of red SBR material online that states it is for water only and not for use with gasoline, oil, etc. So, either most carb kits come with this material that is not gasoline rated (I'd hope not?), or there's something else I haven't found yet.
I am wondering if it is some sort of plant fiber combined with something else - along the lines of the last category listed here:
Thoughts? What do you use?
Grant Forsythe View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 7:06pm
I work at a gasket company. You need buna nitrile, teflon, or viton. I use Garlock 2900. You'll want 1/32" thickness. I make the banjo fitting gaskets for the wc dual fuel zenith carbs.
The Unstyled Collector
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 9:37pm
Thank you! That is exactly the type of information I was looking for.
Any experience with how the shelf life on the 2900 is w/ no climate controlled storage? I can order a decent sized sheet of that stuff but it'll probably take me 5 years to use.
Go figure - Garlock even has a PDF directly addressing this on their website under the Documents section. 5 years sounds great.
Edited by wjohn - 02 Apr 2024 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 6:21pm
Call draco mechanical supply, 800 732 5669. We can sell you a smaller sheet. Usually 5 year shelf life. 0.032" is the size I use. The material should be kept dry, it will absorb moisture if left in a damp climate.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 7:54pm
Wow! Just WOW!
Is this a great forum or what! Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 10:14am
Thank you - I already got a 1/32" x 30" x 30" sheet on order the other day. I will store it in the house.
This page was generated in 0.049 seconds.
