recommended engine oil for hd5 |
serioussam
Topic: recommended engine oil for hd5Posted: 10 Sep 2015 at 2:41pm |
What is the recommended summer and winter engine oil for the hd5 thanks
gemdozer
Thanks(1)
Posted: 10 Sep 2015 at 4:06pm |
For summer time sae 30 and winter time sae 10 for HD5 DETROIT 2 CYL.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Thanks(1)
Posted: 11 Sep 2015 at 10:11am |
I have been using 15 x 40 Shell Rotella for many years .
A good multi-grade heavy service oil, Might add some STP or other zinc bearing additive also as most new formula oils are missing that element from them. New Diesel oils are formulated not to meet EPA rules for Tier 3 and Tier 4 engines or engines with cat converters and much is missing .
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1011 |
Thanks(1)
Posted: 11 Sep 2015 at 11:45pm |
If you have any issue with oil consumption you can use SAE 40. Most of my trucking career I used the 40W for my Detroit 2-cycle engines with good results (bought it at Walmart most of the time). If you have cold winters and you're still dozing you should go thinner. I used the 40W down to 20 deg. F., of course I had the block heater plugged in and sometimes the oil pan heater. I watched an oil testing demo (for metal to metal protection) once. The 40W gave the over all best results.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 21 Sep 2015 at 9:45pm |
Guess since oil pressure was nuttin to be proud of on them 2 strokers, I had heard that you was supposed to run 30 weight in the winter, and 50 weight in the summer. Darrel
Coke-in-MN
Posted: 21 Sep 2015 at 11:30pm |
15x40 gives me about 15 psi idle 40 + running
Eric B
Posted: 22 Sep 2015 at 1:35am |
I've been told by Detroit specialists that if your engine (Detroit 2-cycle) does not maintain 30 PSI oil pressure at full RPM and hot, the bottom end is at risk. They don't seem too concerned about the oil pressure at idle if at least you have 5 lbs. due to the volume from these pumps.
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 30 Sep 2015 at 11:15pm |
I always ran Rotella 15-40 in my HD5
