Recommendations for tire pressure.
Message Reverse Sort Order
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Topic: Recommendations for tire pressure.
    Posted: 19 Nov 2016 at 7:22pm
As Dave said 12 PSI. I started at 16 and gradually worked down to 12. But anything from 12-16 should work for you. Play around a bit and see what you like. You will need a fairly good gauge to be reasonably accurate at that low pressure.
Edited by Ed (Ont) - 19 Nov 2016 at 7:24pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 10:30am
At 16 PSI the max load rating for the pair is 3,740 lbs. assuming you have the standard 4 ply rated tires. Id personaly go down to 12PSI. youll get much better traction  if the tires  flex some. My C with wheel wieghts only I run at 10 PSI.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 9:41am
15 PSI should be good.
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 9:20am
I have a B with 12.4 x 24 Firestone Field and Road tires. Tractor has rear wheel weights, 75% calcium chloride, 3 point, front wheel, wishbone and engine weights.  The 3 point gets used a lot to pick up heavy loads.
What PSI would you air the rear tires to?
