Recommend Good Tires for Loader
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Topic: Recommend Good Tires for Loader
    Posted: 25 Jan 2011 at 10:18am
I need to replace front tires on a big bucket loader tractor.  At least E rated or in the old days, 10-12 ply rated for sure.  Original size was 7.50 x 16 and I just discovered that 11 inch wide pickup tires are too wide and rub against the spindle steer arms..of course.   Any experience with brands or mfg recommendations good or bad.   Seems hard to find a 16 inch less than 11 inches wide with a real load rating in my on line search so far.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 10:32am
Trailer tires?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 10:52am
A 235-85-R16, has a width of 9.25" and a height of 31.75".
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 10:54am
I used wagon float type tires on IH 460 Utility with Henry loader
On the 715B I have a Goodyear tire made for Industrial laoders , might try to look in dealer catalog and see whatthey have for TLB use.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 10:56am
A 215-85-16 tire would work out also unless you are in soft ground. We have some 10ply 7.50-16 3 rib on the front of our loader tractor, but they were expensive..
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 11:36am
Matt where did you get them? 8 ply were from 80-130, couldn't find any 10 ply. My tires break out in the side wall before the tread facing is worn down very much..and I keep them up over 45-50+# pressure. Use to run at 35-40 but didn't hold up at that pressure either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 11:46am
they were from the local Cenex store, I believe they were almost $200 each with the tube.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 4:12pm
Used 18 ply aircraft tire $48.00 plus shipping.  New $108.00.  new on rim $154.00
http://www.noflats.com/tractorfronts.htm
