Rebuilding D17 head costs |
BillinAlberta ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Saskatchewan Points: 357 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Dec 2016 at 9:07pm |
I am probably going to redo my D17-1960 engine. It is burning lots of oil. It was "rebuilt" years ago.It had a hard life until I acquired it a few years back.Sat outside and ran only occasionally and likely not much maintenance done. The bottom end is possible for me but I have never tried to redo a head.What does a complete rebuild cost for a D17 gasser head?Is there anywhere where I can get some you tube vids or online resources on head rebuilding?I'd be willing to try to replace the guides and see if that stops the oil burning but have never tried to do this before. Compression is even and passable on all cylinders and it has quite a few hours of honest work since I got the tractor.Tried seafoam for a while thinking it might be oil rings stuck. Fogs out a liter of oil an hour but is nice and smooth running otherwise.
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9958 |
Take the head to a machine shop. Have them check the head over for cracks, measure valve guides and check valve seats.
Dan73 ![]() Orange Level ![]() ![]() Joined: 04 Jun 2015 Location: United States Points: 6054 |
If you think it needs lower end work as well i would pull the crank at the same time and get it to the machine shop to be measured and checked. I am in the middle of rebuilding my d17. My d17 has been in the family since the early 60s and it hasn't been a part in that time frame but the crank had already been turned to the max and was damaged beyond usage I spun a bearing. I had a hard time finding a replacement crank.
I am trying to remember what I ended up with for a machine shop bill my head was a mess and I think it came to about 500 it was limped into some other bills so I don't remember for sure. My crankshaft was 650 I think. When all is said and done I expect to have 2500 to 3000 in the engine. |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3073 |
I would take it to a machine shop to have the head done. They can tell you what it needs. I valve train kit isn't over $150. It probably needs the block side and manifold side milled, the valve cover side might not hurt either. All together maybe $500?
79fordblake ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: West Kentucky Points: 829 |
The head on my WD45 cost $513 and it got everything. The block work cost $1143. All together I'm a little under $5000.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Ditto on taking the head to a reputable shop. They can tank it and thoroughly check it out; pressure test, flatness, spring height, etc. A complete head rebuild (new springs, valves, guides, seats, and machining it should fall into the $400-$600 range.
Edited by GregLawlerMinn - 22 Dec 2016 at 2:54pm |
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6081 |
Well, if it were me, I'd look it over myself, before arbitrarily committing a wallet-figure to it. Like anything else, a guy can dump entirely too much money into something that provides absolutely no benefit to the circumstance.
When you pull the springs, see if any feel 'spongy'. If it sat for a long, long time without turning over, several valves open could cause a few springs to be sacked-out, and some may be weak from other circumstances. If the guides are worn, smacking them out and pushing in new isn't rocket science. Putting the pilot of a seat-cutter into the hole and recutting the seats isn't difficult either. Not everybody has a valve grinder, but many guys do... I MADE myself one with an old cordless drill, a mitre fixture, and a find grinding wheel... I didn't use it much before finding a better gadget, but it worked. A sucker-stick and lapping compound... dirt cheap. If they're flat enough, just wiggle the valves, if they're not sloppy loose, lap 'em and make sure the springs are all good. If the manifold face is eroded, run over it with a file to find the high vs. low, then pass across with a belt sander to cut it flat enough for good manifold seal. Recheck with file. These heads ain't rocket science... ![]() |
Thanks Dave.I am going to give it a try with the seats.If it doesn't work then I'll go for the machine shop.Parts and labor" all in "at a recommended shop is 700 bucks. Any hints on how to smack out the old seats?
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1770 |
had lots of heads worked on '' never over 100 to 125' theres a guy on craigslist has a nos' new one' with nos' box it came in wants $225oo been on there for a very long time. it's a brand new one'''
How long ago were those prices? I looked at my head before I took it to machine shop. It needed all new valves, springs, guides, seats, freeze plugs, and all surfaces had to milled to make it perfectly flat again.
That sounds about like mine. It was done last summer I ended up with a 650 bull but there was some other work the shop lumped together I am pretty sure my head was 500 out of the bill. When I rebuilt my d15 I had to get a replacement head. That was 650 plus shipping. It was a completely rebuilt head. 5 years ago I think. Edited by Dan73 - 25 Dec 2016 at 9:19am |
been better to just go an buy a head or tractor somewear. it's hard to get some of them prices out of a wd-wc-d17
I will have about 2500 in my d17 motor when it is back together. But I will have a 100% rebuilt motor new everything. You rebuild these because they have history you want to keep. But I will put this question to you as to cost. How long will a 2500 dollar tractor run before it needs major work? I really wanted a diesel tractor that size for haying but it would have cost me about 6000 for a diesel 70 hp here which is what i really want. And that would be an old tractor needing work. I don't think i can justify a new tractor for the farming I am doing it just doesn't have the payback to justify that type of investment. So I fixed what o have and burn way more gas then I want. In a few years maybe I can buy my neighbors 180 with a recently rebuilt motor he is close to retirement and doesn't have a farm any more so he would probably sell it. Right now he hays other people's fields.
There's two primary issues when dealing with a cylinder head for one of these:
First... how bad is it? Second... how 'good' does it have to be? Many people... both consumers, and SHOPS relate cylinder head rebuilding costs to say... carrying in a head from a typical V8. These ain't. On a typical V, you've got a critical included angle, where if you have ANY head milling to do, you have to be concerned with a second plane... if you mow the mating surface of the head, you also need to work on the manifold face to make sure the two planes are true to eachother, lest the manifold will NOT mate flat to the head. On an Allis, if you mill the head, and it isn't true to the manifold plane, it makes NO difference. If you mill the manifold face so that it isn't true, it makes no difference. I had one with the #1 exhaust port so eroded away, that I put it in my Bridgeport with a 3" face mill, shimmed up the front end side by about 0.110", and chewed off a mess of iron... and slapped it all back together. If you look REALLY REALLY REALLY close, you'll notice (mebbie) that the exhaust manifold looks a bit off-kilter to the head, but probably not... and it works great, seals great. The cylinder head flatness... not nearly as critical as most... the gasket and sleeve protrusion do all the work. If the thing doesn't leak coolant into the pan or out the deck, has a good enough compression seal to not burn the gasket fire rings away, and the valves still get close enough to seal, it's good with minimal work. Changing the valve guides isn't difficult... you'll need a drift pin to knock them out. Find a piece of steel rod a little smaller in OD than the valve guide OD, chuck it in a cordless drill and hold the end of the rod against your bench grinder, and spin the drill... grind it down 'till there's a small-enough pin space in the end to fit inside the guide (so when you smack it, it doesn't jump out of the guide). Drive the old guides out with that pin and a 4lb hammer. Driving new ones in is same process, but works best if you put the new guides in the freezer for a day, and dip 'em in motor oil before slipping 'em in and smacking 'em home. Off the top of my head, I don't recall if the Allis guides needed any special attention to height, I don't recall having to worry about it with those (like I did with others), so probably not. When driving new guides in, it's possible to mar the ends a bit such that valves don't want to push back in. If this happens, a light dressing of the smacked end with a tapered hand-reamer will USUALLY solve it, and if they're a bit snug, put a little light lapping compound on an old valve, slip it in just enough to reach the tight area, and work the valve around a little to clear it. I have a very old spring-type ID reamer specifically made for cleaning residue from valve guides (usually on flathead motors), but it does nice job of cleaning up driving burrs. I've never had to put new seats in any of mine... True industrial engines always have hardened valve seats, so they don't wear much. On mine, once I had the guides in place, I just dropped in good valves and used the sucker-stick and some compound to lap them in. In most cases, giving a cylinder head just a little manual TLC will bring them well back to happiness without much investment. My SOP for ANY cylinder head, starts when I'm breaking it down... I check for slop 'tween valve and guide, cracked/broken seats, bent stems, and sacked out springs. I clean the casting up really good, check for cracks. If I don't see anything obviously bad, I just clean all the valves, lap them, check springs and reinstall with a good gasket, carefully cleaned bolts and threads, and a known-good torque wrench. At 1800rpm and 8:1cr, they'll perform wonderfully in typical tractor service without much heartache. For the satisfaction of the pulling crowd, if you're going turbo or supercharging, 10:1CR, nitromethane, 5000rpm, port fuel injection, or breaking in under 10 second ET, then it's worthy of a bit more investment. |
if ya' need one new nos' d17 head on rockford il' craigslist ac ' $225oo 0r $250oo it's for-sale just looked at it .
Well I guess I went about my build a little differently than most. I wanted everything to be absolutely perfect. I have enough money in this tractor to have bought a couple more....that doesn't mean squat to me. This was my Grandfather's tractor and it was worth every penny.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
