Rebuild problems, any suggestions??
orange man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange man Quote  Post ReplyReply Direct Link To This Post Topic: Rebuild problems, any suggestions??
    Posted: 08 Dec 2009 at 8:40pm
I have been going through my allis chalmers c and have posted a few times with questions. So to follow the same path I have a few more questions. Thought I was going to be finished today but doesn't seem so. I got this tractor in mid October after it had sat for six years. I got the tractor started by pull starting it (no battery). After a 20 minute pull it finaly started and seemed to be running prety good so I deceide to drive it the six miles home. After a 1/2 mile it started sputtering and then quite after 1 mile. From there it was trailered home. Once home I cleaned the fuel tank and installed fuel filter/ new plugs /cleaned carburetor. Also found radiator leaked so got that repaired. Deceided to keep it 6 volt so bought a new battery. Installed battery and found out the gear ring was shot. Then relaced the points and condenser in the mag. Pull started and still ran bad. Pulled mag and found broken parts. Bought good used mag and installed. Deceide to split in 1/2 (never done before) and replace ring gear. Changed the throw out bearing while apart. Put back together and deceide to strip down and blast everything. Blasted all parts in cabinet then blasted entire frame. Painted parts then frame and put back together. Installed new plug wires and decals and after a couple of tries the tractor fired up and is running beautiful. Jumped on to test drive and could not shift into gear. All it did was grind. Tried to adjust clutch and could not get it to work. So one more question! Does anyone have any ideas. I dont have a clue. I must of done something wrong when I had split but I have no idea. I can't think of anything that I did wrong. While blasting, could sand have gotten in clutch and done something? Do not have inspection cover for clutch. Did stuff rag into hole and sealed good. Blew out when done and got a little sand but not much. Any help would be appreciated.Thanks Vance
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 8:44pm
Could have put clutch disc in backwards. This could bind it so the disc won't slip when the pressure plate is released.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 8:48pm
Dave,
Did not remove any part of clutch.I did not replace clutch because it seemed to be in good shape. Thanks Vance
Al in WMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al in WMA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 8:49pm
The clutch stuck in my B last spring. Rust I presume, I used the clutch lock to load the pressure plate up and left it for a day.  When I came back clutch had released.
Good Luck
Al
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Education is what you get when you don't get what you wanted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 9:37pm
clutch stuck due to oil on the plates. there is a small drip on the pilot bearing and that oil gets on the clutch. put it in gear , push in clutch and crank.. may start and begin moving.. keep clutch pushed in and see if it lets go. if not, connect to a disc or plow, put in gear and start again, a good load will make it break free.. when it lets go, push clutch in and clamp. remove starter motor, spray dishwasher soap and water into the hole all over clutch, with a weed sprayer. soak it good and hose out with gardern hose. should be lo.k. for another 50 years.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 9:49pm
I had the clutch on my C rust up - had the same symptom described above. I put it in reverse with clutch locked in, put spouse on board to steer, and towed it with another tractor. Came free in about 6 feet. Not sure this is an approved approach - could damage something if rusted clutch wasn't the problem - but it worked.
WC, CA, D14, WD45
