Rearend gears.
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Topic: Rearend gears.
    Posted: 16 Jun 2015 at 12:42pm
I have some new gears to put in a WC rearend was wondering how hard it would be to install or if there where any tricks to getting the axle shafts out. If any one has some info on this I would appreciate it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 2:43pm
What gears ?? Ring and pinion ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 2:53pm
Yes the guy Said they where out of a high crop. But not sure how to get the axle shafts out to get the old gears out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 4:49pm
Anybody?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 5:31pm
A shop manual is pretty handy when doin a job like this. It might make a bit of difference depending on what rear end you have too, steel or cast?
If you o to AGCOparts book, you might see how things come apart. Log in as a guest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 7:50pm
Well I got it out, I couldnt get the agco parts book to work but thanks anyways. By chance does anybody know how much this will slow me down I've heard everything from 10 to 25 percent guess it doesn't matter cause I own them haha just wondering.
Edited by Zaddison - 16 Jun 2015 at 7:53pm
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 5:24am
I think that gear is a 6.6 ratio where the stock is around 4.4. I have a rear end out of a speed maintainer that is a tad slower around 7.2. The 1st thing I noticed is loading on trailer, it crawls right on rather than speeding on. My second gear is about the same speed as fisrt with the stock rear end. you will like those gears. GEt some 15.5's and you have a great combo
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
This page was generated in 0.375 seconds.
