rear wheel weights for 185
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: rear wheel weights for 185
    Posted: 12 Nov 2023 at 6:54am
just wondering what wheel weights are being used for 30" wheels, like on a 185? Brian Ahart has a weight listed in his chart,  258887-02-wa. wondering if there was another option?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 7:06am
David, I've got F&H 161's and 162's on mine mounted similar to how they mount on a WC. Seems to me like I had to index the lug bolts to make that happen.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 11:43am
How and what is indexing the lug bolts? I have a set of F&H weights to put on my 185 with 30 inch rims. Any pointers appreciated. T I A.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 9:04pm
I just put some on from a WD, I also have a set of F&H that fit.  If I remember it is a 14 inch bolt spacing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2023 at 8:05am
Sparky, all that means is to turn the bolt so the flat is against the weight. The points stuck out just far enough the weights didn't want to sit flat on the center.
Edited by IBWD MIke - 13 Nov 2023 at 8:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2023 at 10:33am
Okay Mike I understand now. I’m going to do some measuring and see where I’m at. I think my weights are in the 450 to 500 pound range. Thanks.
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2023 at 2:01pm
I believe the correct weights are 256687 donuts.  I have them available if you decide to go that route.
This page was generated in 0.461 seconds.
