Rear wheel pusher bolts
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Topic: Rear wheel pusher bolts
    Posted: 05 Sep 2020 at 8:21am
I have several extra rear wheel pusher bolts for the 100 series and also the 7000 & 8000 series. $50.00 per bolt. Just tell me what size and how many you want. Freight will be extra. Central Iowa location. Can call me at 515 370 3002.
Edited by Lynn Marshall - 06 Sep 2020 at 9:42pm
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 5:13pm
Each set? or each bolt?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 5:27pm
PM sent
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 9:43pm
I edited my post to reflect that the price is per bolt.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 7:10pm
Witch ones u need for a D-21. Thanks
nonetheless ,still dead.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 8:24pm
I believe they take the same as a 190
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 8:32pm
Fred, from what I can tell from the Agco parts website, it looks like a D21 uses the same style of tapered hub like a 190 or 200. It does not use the two piece taper wedge system that a 210,220 or 7010 and up use. The D21 uses the same pusher bolt that the 190,200,7000, and I suppose the D19 also. I've got 16 of those. I am confused on the 210 and 220 though. They list a different part number of pusher bolt than the 7000 & 8000 series ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 7:52pm
I sold some,  but still have plenty of these bolts for sale.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 10:25am
sent pm
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 9:38pm
Plenty of these bolts left.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 8:11pm
I still have a few of these bolts sets available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 8:30pm
Can you tell me what this pusher bolt 254071 will work on. Which tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2023 at 7:56am
I'm not sure about that part number? If it's 7/8s fine thread, it's for the larger tractors 7010-7080 and 8010-8070. Coarse threaded ones are for D19,190,200 and 7000.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2023 at 8:02am
The pusher bolts for the larger tractors with the two piece wedges have a 7/8" 12 thread. This is NOT a standard NC or NF thread. It is a special industrial thread. ON tractors with the single piece 3 bolt wedge such as the D19 etc, the wedge thread is standard 3/4" NC
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2023 at 5:07pm
Mike, if I'm reading the master parts number book date 6-69 right  it's for  220
Edited by Kenny L. - 04 Jan 2023 at 5:09pm
