rear tire size od wd-45
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: rear tire size od wd-45
    Posted: 16 Oct 2010 at 7:15am
I need to know what the factory rear tire size is of a wd-45.  I don't have mine close and am looking for snow chains for it. I have found info that lists 3 different sizes. Thanks again. Mike
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 7:25am
12X28 was stock with 11X28 option. I think the guys who know more say a 12X28 converts to 13.4X28 in todays sizes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 8:05am
Most true WD45's had 12-28's (13.6 x 28) or the optional 13-28 (14.9 x 28) on them....usually WD's had the 11 x 28 (12.4 x 28).
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 10:17am
To be sure you have to look at your tires. With the factory picking two or three different sizes and users going bigger later, you might not get the tire chains to fit without extensions on the chains.
Gerald J.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 6:41pm
I grew up around WD-45s and most in Northcentral In. had 14.9x28 on them and only the very early 45s had  the13.6. Dad also got a 1948WD and it had  11x28 and the 1950 had 12x28s or 13.6 on it.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 3:55pm
The chains I took off are 10ftx2ft +- The set I bought are 12fx2ft so I should be in good shape. If anyone needs a set of road chains that's what I took off. I needed more aggresive chains. Thanks again for the help. Mike
