Rear Rim OK? |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Jul 2017 at 7:55pm |
I just took the tires off of the rims. One rim is in real good condition. The other is rusted all the way around. It appears solid. How does one tell how thick the steel still is and if it would be useable?
I'm not planning on loading the tires or adding weights. |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8367 |
Peck around on it with a welders sl*g hammer and see how much metal comes off, hope you don't see daylight, whats it on ?
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
You should remove as much of that as possible. What tractor, what size tire?
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Have had a number of them done over the years and remember the first one as it seemed there was not much to them for wall thickness. I clean em up best I can by removing excess rust with hammers, remove any sharp edges around the flange and work them back true with hammers. Had a few where they had pin holes after blasting and wire feed filled them nicely. Good primer on the inside and I always run new tubes when going back together. Have had new metal installed on a few, up to 2"+ around the valve stem area and you cannot tell where they were done. If the weld shop I use can do them for 1/2 the cost or less (including freight on new rim), I have him work his magic as the wheel stop holes on replacement rims tend to be half a hole off when moved to the innermost setting.
It's a 28" PA rim. Will be going on a D-17. I guess I'll start hammering on it and see what happens.
Dan Hauter ![]() Orange Level ![]() ![]() Joined: 06 Feb 2011 Location: Carlinville, IL Points: 1258 |
Do you have a metal guy you trust to give you an honest opinion? If in doubt an opinion from someone competent will send you in the right direction.
I do, but I'm not sure when I'll see him again. I was hoping someone on here had an idea. Someone usually always does! |
FloydKS ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: S E Kansas Points: 8423 |
It is hard to have an idea without seeing the rim.
