rear lift capacity wd45 vs. series 1 d17
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: rear lift capacity wd45 vs. series 1 d17
    Posted: 15 Oct 2023 at 8:54pm
will the series 1 d17 lift anymore weight than the wd 45  what about the series 4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 10:55pm
Series 4 will lift more than both the others. D17 will lift more than a WD45. THIS ASSUMES EACH TRACTORS HYD PUMP IS SET CORRECTLY FOR PRESSURE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 11:16pm
just started useing  a  bigger triple k digger thats got one more row of danish harrows  and a harrow bar on the back plus it has wings i can pull it with the wd45 but i cannot lift it if i am idleing i can get it up  it hits the relief, i dont have pressure gauge on that tractor           hope fully i will have the d17 done by spring
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 10:09pm
My D17 will outlift my WD45 hands down...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 10:34pm
The first two generations of the D-17 had a slightly smaller diameter ram than the series 3 models. These all used the high pressure 3700 psi piston pump. The series 4 went to the "live" low pressure 2,200 psi system, so they had to go with two external cylinders and in the end they were the most powerful of them all.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 6:52am
Here’s some previous AC forum posts about the subject.
https://www.allischalmers.com/forum/wd45-lifting-arms-cap_topic175728.html
https://www.allischalmers.com/forum/d17-lift-capacity_topic163554.html%20
Edited by AC7060IL - 18 Oct 2023 at 7:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 7:55am
this wd45 has a f11 loader , rear tires with calcuim am and three weights on each rear wheel on it and it makes the front light  , on my wd it just lifts the front end off the ground no extra weights
