Rear hub noise problem on 5050 |
AC Pete ![]() Bronze Level ![]() ![]() Joined: 27 Aug 2024 Location: WI Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Aug 2024 at 11:33am |
Hi guys. Having trouble identifying a noise that seems to be coming from the final drive on the left real tire. It happens at the exact same tire position on each revolution. With rear end jacked up and turning tire manually it turns freely until we get to that exact spot where it binds up and with moderate force I can turn the wheel about 6 inches to get past that spot to turning freely again. With both wheels off the ground and both transmissions in neutral the right side does the same, but the noise seems to come from only the left side. I can't say for certain that this noise is coming from the final drive though. Anyone have any thoughts as to what might be going on? Thanks for your time.
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4723 |
Since nobody else wants to stick their head out from under their rock
I M Fedup ![]() Bronze Level ![]() Joined: 01 Jul 2020 Location: Winchester Ky Points: 28 |
If it's consistent with wheel/axle rotation it almost has to be something with the bull gear. I'm thinking something like a shard of bearing cage jammed into the valley between two teeth? I would say take it apart before it gets worse. At this point it would mostly involve some time/ effort, a gasket, and some oil.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3073 |
I'd be looking to see if the brake was dragging at that spot
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21812 |
If one marks the rear tire to the "noise" spot and it is consistently at that spot, it is likely a bull gear tooth. The brake and bull pinion are at a different ratio and would never come up to the same "spot" on the tire time and time again.
