This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | ||||
The Forum | Parts and Services | Unofficial Allis Store | Tractor Shows | Serial Numbers |
Rear Electrical Outlet ? |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5389 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Jan 2022 at 5:54pm |
To those that run a D series/100 series tractor(s), do you use the 12 volt outlet for anything? We attempted to run the monitor for a JD planter off of it, but that was an epic fail
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 44734 |
That terminal is just a voltage checker. you use your tongue, make sure to touch both terminals!
What a waste
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 16363 |
It was intended to operate rear lights on any implements you were pulling, so if you turned on your headlites, the planter monitor should have worked.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 66772 |
DR... were they just 18 gauge wires ? Maybe a 5 amp load ? Not heavy duty 12 gauge for "OTHER" 20 amp loads ?
The light circuit was on a 20 amp fuse and this connection was part of that circuit. 18 or 16 gauge wire. One tail light on an implement was what it was designed for.
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2646 |
When I was in high school, we used a One-Seventy to pull a homecoming float. I wired up some floodlights on the float and used the connection on the tractor to provide the power.
Codger ![]() Silver Level ![]() Joined: 23 Dec 2020 Location: Illinois Points: 438 |
I did something like that to a friends 175 by replacing the power receptacle with a 7 pin round type and wiring it into the tractor with a forklift reverse switch to serve as a brake lamp switch. Worked well as his boy was on the HS football team and that tractor shuttled the team around the infield whenever a home game, track meet, or local parade was taking place. Plenty of lights and strobes too.
Sadly, between the battery, VR, key switch, HL switch, the JD monitor went hay wire
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 31745 |
I used the two post receptacle to run the electric speed control adjuster on the NH square bale thrower. Hooked it up under the dash to have power when the key was on.
On the 190, I just wired in from battery post on the solenoid an extension cord cut off to length with female end, then used the male end and wire nutted that to the Vermeer round baler electric twine tie. for two years I would grab the plugs and connect to tie, and reverse connect to return the arm... until I mounted a momentary contact double throw double post in the cab and wired it for forward and reverse. was much nicer to bump the switch. and the plugs are still used for when hooking up the baler and unhooking. |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 10764 |
Now that there was funny Dave! ![]() Steve@B&B |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 3215 |
A warning light plugs into that plug on our D15 Series II and attaches to a wagon or piece of equipment. The light is still in its factory box in our shop.
