rc
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Topic: rc
    Posted: 22 Mar 2011 at 9:23am
whats a allis rc going for?  runs and needs nothing but paint ?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 3:32pm
The tires could make $1000 difference, does it have the correct wheels in front and the correct bolts on the rear wheels. Could be from $1000 to $2500? Pictures would be great.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 4:15pm
Check the engine serial #  Should start with RC,  If it starts with CE the engine is not original.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 4:53pm
Actually, the original engine serial # should start with just a "R" prefix. A suffix with a "G" is a gas engine..."K" is distillate, and that will bump up the price, and the original engine serial # compared to the tractor serial number should be relitively close as the same engines were used in power units and such...rear wheel center should have one "mousehole" VS 2 as seen on the WC. I know this was covered before some time ago, but there are a lot of details that are specific to the RC. As Lonnie stated too, rubber condition is obvious, and pics would be a plus also. Let us know what happens...Chad
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 7:39pm
I do know it has the r on the motor flange ahead of the serial number. I did not check the number for a match to the rear end . And I am not sure what a mole hole is on wheels. Rubber is pretty good and metal is straight. I am thinking he wants more than it worth to me so I well probably pass on it . Might regret it later but money is tight right now and I do have other project.
myallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote myallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 8:15pm
If your not interested PM me. I would most likely be interested. I have seen these on other sites for 5000 to 5500. I tried to buy one that was not running and the guy would not get rid of it for 2500 that I offered. Would love to have one that runs with out having to overhaul it. These are rare tractors. Thanks for any info!
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 9:26pm
The engine and rear end serials won't match but should be fairly close in numbers.
Thanks
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 7:50am
  Thanks guys I am going to talk to him this weekend agian and check the numbers and the Mouse holes on the wheels.
