RC
ag orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ag orange Quote  Post ReplyReply Direct Link To This Post Topic: RC
    Posted: 30 Oct 2015 at 12:16pm
we installed new rubber wheel seals (got from Steiner )
now wheels drag hard and you here a rubber screeching sound
any fix for this
Thanks
AG Orange
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 12:30pm
Are you sure the noise is from the wheel seals and not the brakes? If it is the wheel seals, it should subside after you drive it a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ag orange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 12:43pm
driven it quite a bit
if I pack the back side of seals with grease would that help
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 2:23pm
Before I would try that, I would check to see if everything is assembled correctly. Is the problem only on one side? I can't see why you should get any noise from the seals, if they are installed correctly.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 6:27pm
If they are dry they will squeak.
bluewavecaptain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluewavecaptain Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 9:10pm
Ours squealed for over a year. Give them a bit to wear in.
Charles(Two Rivers,WI)
ksbowhunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowhunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 4:11am
Mine on my WF squeal also just drive it a while they will wear in.
2-37 WC
37 wf127
37 wf130
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 8:49am
Spray WD40 around the seals and they will stop squealing.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 6:37pm
If you put it together wrong it will be noisy. Don't ask how I know this.
