RC Wheels
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Topic: RC Wheels
    Posted: 21 Mar 2013 at 12:30pm
Are the pressed steel wheels for a WC Also corect for a Allis RC...?
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 12:37pm
I think RC's had 24's and at least the styled WC's have 28's
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 1:05pm
Front Wheels?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 2:01pm
If you are talking rear wheels the RC didn't use the 24" pressed wheels and if you mean the front the RC had 15" and the WC had 16" but all the wheels do interchange.
Waukesha B, B, IB, G, styled WF, D17, 615 backhoe, 2-Oliver OC3's, 5 Ford Model T's, 3 Model A Fords, 34 Ford coupe, 57 T-Bird
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 4:00pm
I'm with Lonnie !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 6:37pm
I have a friend looking for parts to make his RC Allis complete . WE have 1 front 15" rc wheel.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 6:46pm
RC's had 28" wheels.   I have an RC with 24" pressed wheels but they are incorrect. They work and look fine though. my RC does have the correct 15 inch front wheels though.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 7:39pm
  front wheels are 15"    rears arew 28" with cast iron centersan only one opening for valve stem   wc will fit but not the correct center  also mounting bolts are different square heads
 hard to find   hollow out heads
Jack C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack C Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 1:34pm
On your RC, what did your 24" pressed wheel come from? Did they bolt right up, or did you have to modify the wheel center?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 5:23pm
Some of the late unstyled WC's had a 24 inch pressed wheel. I don't know for sure how many did or exactly when.
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 5:31pm
Would anyone have a good set of 15inch Wheels for an RC for sale?
Edited by ZachD89 - 22 Nov 2016 at 5:32pm
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 7:02pm
The front rims are 15 inch but have the big bolt pattern like the 16 inch wheels, I've discovered some of the smaller Massey Harris tractors like the model 30 or 101jr share the same front rim. I needed a set for my RC and sicovered this. Hope this helps out
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
This page was generated in 0.088 seconds.
