RC starter
khoney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote khoney Quote  Post ReplyReply Direct Link To This Post Topic: RC starter
    Posted: 20 Feb 2024 at 7:10am
I am wanting to put a starter on a RC that I am restoring but see there are 10, 12, 14 tooth starters available that say they fit.  Which one is really used for a RC?    There was no starter on this tractor before so have nothing to compare.   Thank you
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2024 at 7:42am
if it's like a WC that came without a starter, you'll need to be sure it has a ring gear on the flywheel for the starter to engage
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2024 at 8:06am
The 1107017 Starter motor is the one you'll need for the RC. As Joe mentioned, pop the cover out of the Starter hole and make sure there's a ring gear there. Some do, some don't. If it doesn't, I believe the WC ring gear is the one to use. My RC had a ring gear.
I have an 1107017 Starter motor for exchange on the shelf if you have a core. If not, I don't usually like to sell Starter motors outright, but if you can't find a core, I can help you out with this one....
Steve@B&B
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 8:37pm
Our crank start RC had a ring gear already when we pulled the starter hole plug. We had a good starter, foot rod, & mounting hardware on a “parts” WC. The battery box was junk on this parts tractor…so we just ordered a new one for a WC and everything worked great. We don’t have lights on our RC, so didn’t even bother with a generator. Put a good 12v battery in it & just charge the battery a couple times a year. Now that my nearly 90 year old dad doesn’t have to hand crank it, this has become his favorite tractor, because it’s so easy to get on & off. Kip
