RC clutch pack fit b125
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: RC clutch pack fit b125
    Posted: 04 Jun 2025 at 11:12pm
Got a b125 power unit on a 60A combine and was wondering what engine and clutch parts would interchange with a RC?
Have a fellow member who has a nos RC clutch disk and pack and wondering if it would work on my b125?
He also has an overhaul kit for a RC but pretty sure that will work.
Thanks,
Gavin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2025 at 6:28am
An "RC" actually had a "C" engine, not a "B", so it is a little more HP. The flywheel is larger in diameter to meet the starter, so I assume the clutch and pressure plate are different too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2025 at 7:03am
 Funny that when an RC tractor was built, the model C did not exist. The engine used for the RC tractor (R code block) was a BE type block (which at that time was 116 CID) that was punched out to 125 CID, which at the beginning of the Model C production became the CE block that was now standard issue for all the B & C tractors.
  AS for the RC clutch disc, it has the 1-1/4" diameter WC center splines and is smaller than  a WC disc , but larger in diameter than the B/C/P-U disc and is a unique part only used in the RC tractor. The RC flywheel is also a unique item that was only used in the RC tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2025 at 7:16am
I should have been more accurate. The 1939 RC had what was to essentially become the "C" engine introduced in 1940. The 125 cube version of A-C's small block engine.
Edited by DrAllis - 05 Jun 2025 at 8:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2025 at 9:14am
So the late RC would be the same?
I think my b125 is a later one…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2025 at 8:54am
Here is the RC one…
The part number on the tag comes up as a for a C….
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2025 at 2:22pm
Is that number 70216965?  the parts book shows that number to be a Rockford pressure plate not the Auburn pressure you have pictured. What is the diameter of the driving surface?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2025 at 5:55am
Just remembered, no clutch plate will interchange without some work.  The RC used the smaller diameter B/C clutch, BUT used the WC spline center.  You'd need to rivet the WC splines onto a C plate.  Or find a clutch shop to redo your RC plate.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2025 at 11:15pm
Think it’s a 9” but have to confirm..
Measured original on b125 and it is 8.5”
Original is absolutely shot due to rust.
Half of the springs are rusted through.
