Rattle can paint |
Morris Hill NC
Joined: 16 Sep 2009 Location: Youngsville NC Points: 41 |
Topic: Rattle can paintPosted: 28 Nov 2009 at 3:20pm |
Has anyone used TSC Valspar Restoration paint , has #3345 AC Orange
on can cost $7.99 per can. AC Orange # 5339-03 cost $4.99 . Question is which is correct for Allis G & is Restoration a better Paint? Thanks Morris |
morton(pa)
Joined: 11 Sep 2009 Location: Lancaster, PA Points: 1234 |
Posted: 28 Nov 2009 at 3:25pm |
Most of us on here have agreed that the Krylon 1820 is a real, real close match for Persian Orange 1, and it holds up really well. If you want to use the rattle can, thats the way to do it. If you want a good quality restoration job, use a spray gun with good auto quality paint. Don't forget proper preparation is a key to any good paint job.
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 28 Nov 2009 at 4:05pm |
I don't think either Valspar rattle can orange from TSC is correct for a G if you want to match PO#1. Some folks like the Rattle Can shade of Orange that comes from Krylon. Having used it on the Build a B parts and being a painter, with a eye for color, all my life. It is not a real real close match for PO#1. If you want to use a inexpensive Alkyd Industrial Enamel Lowes can scan, mix and match a dry PO#1 sample. Enamel Hardener can be found at TSC And Attwoods.
Speaking of Attwoods. They carry the Vansickle line of tractor paint here in Kilgore Texas. They have both PO#1 and PO#2 in spraycans. At least the can caps are different enough to tell the difference. I wanted to try some but put it off till later. Anybody used any tractor paint from Attwoods Farm Stores?
MilesGray (CO/KS)
Posted: 28 Nov 2009 at 5:28pm |
Ken, I have used the VanSickle PO#2 on my tractors and have had no problems with it. I have it on a 38 B and a 44 C. I bought the 38 restored but needed some touch up and it seemed that the person who restored it, used the same paint, as it matched perfectly.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
Jeff Z. NY
Posted: 28 Nov 2009 at 6:22pm |
Brian Jasper co. Ia
Posted: 28 Nov 2009 at 6:34pm |
I have some of the Valspar paint right now. It's P.O. #2 which isn't "correct" for anything older than 1960. I don't think it's as good as the urethane paint I put on my Oliver, but for a working machine it would be fine. I got it because I repaired my rims and put new tires on the D17 and just wanted to cover the bare metal after sandblasting. I'll use more of it when I put the head back on. I just don't like to put ugly parts back after I've gone through the hassle of refurbishing them, especially when I have a blasting cabinet to quickly and easily remove all the pld paint and rust.
CTuckerNWIL
Posted: 28 Nov 2009 at 6:39pm |
Somebody posted this chart on here awhile back. I think the 2 middle colors look closest to PO#1, the color you would want.
CTuckerNWIL
Posted: 28 Nov 2009 at 7:20pm |
countryguy828
Joined: 11 Sep 2009 Location: Arcanum, Ohio Points: 129 |
Posted: 28 Nov 2009 at 9:44pm |
If you wanna stick with TSC paint, Get the Kabota Orange, Thats what I have been useing on My CA. It's pretty close to PO#1 for cheapo paint
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2164 |
Posted: 29 Nov 2009 at 9:30am |
I've gotten the Van Sickle PO#1 & #2 at Orscheln for $4.49 a can. They also carry the corporate orange in the rattle can.
Bill (E.C.MO)
Posted: 29 Nov 2009 at 10:26am |
It was me who posted the rattle can color comparison awhile back. I've picked up a few others since then and will post an update eventually. To my eye, none of them are a great match to PO2 or especially PO1, based on comparing them directly to meticulously restored tractors i've seen at shows. While PO1 tends to be somewhat "brown" compared to the "redder" shade of PO2, the Van Sickle PO1 is looks "too brown" to me. Some day I'd like to get a chip of the well-accepted PPG versions of PO1 and PO2 to put in the chart.
Ken, I "think" the Van Sickle paint at your Attwoods is probably the same that we buy here locally at Orscheln's, all three versions are in the above chart. The Tisco paint is made by Van Sickle and probably the same. In the rattle can version it's extremely slow drying and not really great quality relative to some other aerosols. Edited by Bill (E.C.MO) - 29 Nov 2009 at 10:44am |
A-C's currently on the farm: B, CA, 2 D-17 D's, One Eighty, ass't implements.
Kraig (WI)
Joined: 19 Sep 2009 Location: Fairchild, WI Points: 163 |
Posted: 29 Nov 2009 at 10:39am |
I have used the Valspar restoration paint and it looks good on my working tractors and doesn't sun fade. For the money, it's a good paint. Kraig (WI)
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72 |
Dave (NE)
Posted: 29 Nov 2009 at 11:27am |
I didn't think the PO#2 Van Sickle was too bad a match. I agree the PO#1 appears a little dark/brown, but wasn't too bad for a small job. I've not been happy with the quality of tractor/implement paint from TSC in the past.
Brian Jasper co. Ia
Posted: 29 Nov 2009 at 4:17pm |
Back when CT Farm and Country and Quality Farm and Country were still in business, their paint was made by Iowa Paint in Des Moines. Tisco also used IA Paint back then. Even the Bush Hog folks used Iowa Paint. It was fine as long as the machine was stored inside. Back then I didn't have a place for the CA inside and it faded really bad. TSC might have used Iowa Paint too.
Kraig, how long ago did you apply the Valspar paint and is it on equipment that sets out? |
Joined: 11 Sep 2009 Location: illinois Points: 90800 |
Posted: 29 Nov 2009 at 7:56pm |
i bought the VALSPAR restoration paint with harderner. Goes on real nice, and dries fast. I bought the "allis chamlers" orange and it looks like corporate to me. I used it to paint a small Economy tractor and a trailer, not a B Allis.
David Gantt N.C.
Joined: 12 Sep 2009 Location: North Carolina Points: 379 |
Posted: 29 Nov 2009 at 8:12pm |
I have used the Tisco paint a good many times, it was real close and going on working tractors.
Joe/NC
Joined: 11 Sep 2009 Location: Smithfield, NC Points: 265 |
Posted: 29 Nov 2009 at 10:12pm |
I have used it and it fades. My older D 10 could be the cover jacket for Dolly Pattin's "Coat of Many Colors" song;; because of TSC paint. But it is better than rust, until I retire and paint it right.
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Posted: 30 Nov 2009 at 8:03pm |
Would the rust-oleum orange paint be close to my 7000 series tractors? |
John_SWPA
Joined: 21 Oct 2009 Location: Burgettstown,PA Points: 148 |
Posted: 30 Nov 2009 at 8:20pm |
Morris,
Do you have an air compressor? IF so, your best bet is to buy a paint gun and shoot the paint on, rather than using rattle cans. Harbor Freight has a $9 paint gun that is decent, but does need set-up by a professional. If you are interested, I could set it up for you if you wanted to ship it to me. I am a professional autobody painter and I own many high end guns, but I do own about 10 of the harbor freight $9 guns that I use for primer and industrial and even the occasional car if I want to show off. (why so many?) I bought 3 guns to start so I could mix PPG NCP-271 primer in 3 separate batches, for shooting several vehicles at teh same time, and having a fresh gun loaded with primer for each coat. NCP primer turns to jello in a paint gun in about 30-45 minutes, so you have to move fast, but have to give it 10-15 minutes between coats. so the consistency varies between the first coat and last coat, unless you mix new batches for every coat. but anyway... Paint guns are very simple to use, and very simple to maintain, and clean. Cleaning a paint gun is probably everyone's biggest downfall, but if you buy some laquer thinner with the sole intention of using it to clean up your gun, you will be fine. Just get a gallon of laquer thinner, and use it liberally to clean. Don't be afraid to waste it. |
John-
"If I can't fix it, I'll fix it so no one can." |
Morris Hill NC
Posted: 01 Dec 2009 at 7:38pm |
All
Thanks for the info on the paint . I dont post often but when I have ask a Question I get a lot of answers REAL NICE bunch of folks on here THANKS Morris |
