Radio |
Post Reply |
tbird
Bronze Level Joined: 01 Nov 2013 Location: usa Points: 121 |
Posted: 12 Jan 2020 at 11:21am |
Have a radio that is pos hot can I book it to a pos ground
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7970 |
It's neg ground. Don't have enough knowledge to say for sure but doesn't sound like a good idea. Hook it directly to battery ...pos to pos neg to neg. Don't worry about tractor polarity.
Jim.ME
Orange Level Joined: 19 Nov 2016 Location: Maine Points: 934 |
I would do a whole lot of continuity testing or I would total insulate it from the tractor if I was going to hook it direct to the battery. There might be a ground in the case that would carry to the tractor when mounted.
Orange Level Access Joined: 12 Sep 2009 Points: 19475 |
I thought the old "Automatic" brand fender mount radio had a small cover on the backside that allowed you to change the radio polarity ??? Been 50+ yrs ago...………..
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33623 |
Turn the tractor to negative ground...
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21451 |
NO !!! Well NOT easily.... you'd have to mount in a wooden box or somehow TOTALLY isolate it from the tractor AND the antenna CANNOT ever touch the tractor either.... ...thinkin... hmm. assuming the radio is 12 volts,you could repolarize the generator, flip ammeter connections and that would be OK ..... as the tractor is now a negative ground.... |
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
jaybmiller
yeah, uses car body as the ground plane , that's why you can't bolt the antenna to the tractor as it'll sort out a +ve gnd radio. just another reason to go 12Volt -ve ground..... 'normal' radios will work....
Post Reply | |
