Radiator Help - WD45 Stuck Guage |
Jeff(WD45-SATX-TN)
Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443 |
Topic: Radiator Help - WD45 Stuck GuagePosted: 13 Nov 2009 at 10:01am |
The radiator in my WD45 is in excellent shape for its age, and for sitting full and not running for 10 years or so. The temp gauge on the other hand did not weather so well. Totally rusted, and will not budge from the water neck. Anyone out there have a solution for removing that rusted part from its resting place? I have tried liquid wrench, several doses with time, as well as a little heat. Still no action. Do not want to ruin a perfectly good radiator, but need a new gauge.
Jeff
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1571 |
Posted: 13 Nov 2009 at 10:29am |
Toss liquid wrench, get some PB Blaster, cut off face and use a socket.
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 13 Nov 2009 at 12:00pm |
This is what I'd do too. lol
Gil (cent MO)
Joined: 11 Sep 2009 Location: Jefferson City Points: 31 |
Posted: 13 Nov 2009 at 12:53pm |
Be very very careful you don't twist the guage socket out of the radiator. (use two wrenches) Gil
Osage_Orange
Posted: 13 Nov 2009 at 5:27pm |
After doing the things recommended above, I would use two wrenches, and "tap" the one I want to move with a hammer. Sometimes a slight impact is enough to break the rust loose. |
Why is there never time to do it right the first time, but always time to go back and fix it?
bigfish_Oh
Joined: 13 Sep 2009 Location: West Liberty,Oh Points: 1226 |
Posted: 14 Nov 2009 at 12:47am |
sometimes none of that works, I will never put a gauge back in that neck I trashed !!
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe 1951 WD, factory p.s. 1960 D14 HnMk IV BkHoe 4 sale 2014 HD Tri Glide 2009 GMC CC SLT Dually |
CTuckerNWIL
Posted: 14 Nov 2009 at 8:48am |
And use a good 6 point socket, not some 12 point hex rounding one.
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 16 Nov 2009 at 6:18am |
After you have applied some penetrant such as PB Blaster or Kroil (better), take two small hammers (I use 8oz.) and tap the neck with one hammer while using the other as a backer. Work your way around the neck so as to tap from all sides, helps the penetrant work and helps loosen the rust bond.
