Radiator Foam |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: Radiator FoamPosted: 14 Dec 2016 at 5:07am |
The Foam seal around my 190xt radiator has fallen apart. Suggestions on what to use to seal around the tin work to keep the air flowing through the rad?
Charlie
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54739 |
Posted: 14 Dec 2016 at 5:14am |
best would be closed cell foam. I think the box lumber stores sell it as draft stop foam for windows, doors and sills...
DougS
Posted: 14 Dec 2016 at 5:37am |
You can try that expanding spray foam, though it's hard to do a neat job with it. Remember that a little goes a long way.
Charlie175
Posted: 14 Dec 2016 at 5:38am |
I'll have to check it out.
I need to put it back together to see how much clearance I have to fill in.
Charlie
Charlie175
Posted: 14 Dec 2016 at 5:40am |
Umm, that would stick to both surfaces and then the hood could not be removed? |
Charlie
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 14 Dec 2016 at 5:48am |
One of the electronics repair places I used in the past would use expanding foam but they sprayed it into a bag inside the box. The plastic bag made it come apart later and the foam made the box into a perfect shipping container for my part.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5910 |
Posted: 14 Dec 2016 at 6:06am |
I was thinking a thin piece of plastic as well. Would a piece of 'Saran Wrap' stick to the hood. Put Saran Wrap' on, then assemble. Gary |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 14 Dec 2016 at 6:11am |
A good big box store may have the thick foam backer that window installers sometimes use to fil BIG gaps,if not found, that rectangular selfadhesive door foam will work. If you need extar extra height ,just put 2nd layer on top.
I would NOT use spray foam. too messy, too uncontrollable,it's a nighmare in a spray can !! |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12337 |
Posted: 14 Dec 2016 at 6:39am |
I used pipe sleeve insulation for my 7045. For the most part, I cut it in half length ways into various lengths and shapes. For a little tidier job, I could have used adhesive or double sided tape or something, but mostly I used zip ties. Seems to work fine. Guys on here say the kits are still available at Agco, but no dealers around me. Not one of Allis's better traits in my book.
Lonn
Posted: 14 Dec 2016 at 7:19am |
Wink I am a Russian Bot |
skateboarder68
Joined: 29 Jan 2011 Location: Keota, IA Points: 372 |
Posted: 14 Dec 2016 at 7:29am |
I'd see if Ago has it, redid a 7045 foam a couple years ago and got the stuff from Agco it was right and will be good for 35 more years and it looks good.
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8761 |
Posted: 14 Dec 2016 at 8:37pm |
The new AGCO foam I bought in 2010 for my 8070 is crap now....kinda disappointing for $75.Aint been oily or nothing.No expansion left to it and it sucks out of place ending up hanging down front of radiator.Maybe 300hrs
JCFarms
Joined: 03 Mar 2013 Location: Louisiana Points: 230 |
Posted: 14 Dec 2016 at 9:29pm |
I used the foam out of my old tractor seat from my 8010. Works great.
Unit3
Posted: 14 Dec 2016 at 9:36pm |
For years, I used 3" memory foam. It worked great, right up to the point when it caught fire this fall.
wayneIA
Joined: 17 Oct 2009 Location: Waverly, IA Points: 268 |
Posted: 15 Dec 2016 at 12:39am |
I found in the local hardware store they have foam for sealing around air conditioners, it comes in like a 3" x 3" x 36" piece along with a smaller size available (1-1/2" X 1-1/2" X 36"?)depending on the hole to be filled. I used it on a 7060 and my D-21.
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 15 Dec 2016 at 3:59am |
I save old couch cushions, and when I need foam for anything I cut it with an electric knife the size I need. i've used this thru the years for the tractors too! they also work good for making new seats too.
Charlie175
Posted: 15 Dec 2016 at 4:41am |
Thanks for the ideas
Charlie
Lonn
Posted: 15 Dec 2016 at 6:37am |
