Radial tire pressure
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Radial tire pressure
    Posted: 27 May 2011 at 7:58am
What is the proper air pressure for radial rear tires.  They 20.8x38 on a 8030 that will be carryring a decent amount of weight on the 3pt.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 8:06am
Single or duals?How much is decent amount of weight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 8:22am
The duals go on and off.  Enough weight that a 6080's front touch very lightly at best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 8:24am
10# for duals,16#for singles.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 5:20am
Bob is right if the tires are tubeless. If you have tubes , they should be natural rubber for lower pressures. If regular tubes the pressure will need to be higher or you will develop rubber crumbs and eventually the tube will fail.
