RAD, FOAM KIT 7060
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: RAD, FOAM KIT 7060
    Posted: 31 Dec 2010 at 8:25pm
 HELLO
OTHER THAN A DEALER  DOES ANYONE KNOW WHERE I CAN GET A RADIATOR FOAM KIT FOR A 7060?
bugbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bugbird Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 8:53pm
Have done this many times.  Go to Hobby Lobby or JoAnn Fabrics, maybe even WalMart.  Buy foam rubber in sheets and cut with utility knife into 2 or 3 inch strips.  Spray adhesive or 3M weatherstrip glue.  Lots cheaper and works well.  Compress the foam while cutting and hang panels back on until adhesive sets.
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 9:30am
The foam kit part number is 70270115. I suppose the price on them is getting a little silly, too? There seems to be a lot of that going on anymore.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 10:33am
I got that top one for 8070 a year ago.I think it was around $50,maybe it was $150....I don't think I'd took it at that price.The tickets around here but I'm lazy.
Bertman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bertman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 12:14pm
Menards is a good place to get it.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 2:47pm
I did the same thing that bugbird did with our 7020 and 7045. Easy to do and worked well.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 2:53pm
To cut form rubber a electric carving knife works real well, the blade action does a real good job without compressing foam. many Motorcycle seat upholsterers use it to fit foam to rider specs.
 just be sure to clean it good before replacing in the kitchen and don't tell the wife.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 5:37pm
THANKS FOR THE INFO. I HAVE A QUESTION, THE FOAM ON THE TRACTORS WAS EITHER BLACK OR GREY, THE ONLY FOAM I HAVE SEEN IS YELLOW, DOES ANYONE KNOW THE DIFFERENCE?      AND THANKS FOR THE MENARD INFO BUT SORRY NO MENARD IN SOUTH LOUISIANA
