R62 smartrac, option or standard
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: R62 smartrac, option or standard
    Posted: 26 Oct 2016 at 11:34am
Just wondering if the smartrac feature was an option or if it was standard on all of them. Also were does it flex, in the throat?
Thanks
Leon B Mo
Edited by Leon B MO - 26 Oct 2016 at 11:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 12:15pm
When the R-62's came out in 1992, the smart-track wasn't even invented yet. I doubt that it was ever STD on a wheat machine. The throat is about 3 inches fatter on the front face moving the header forward a bit. I always said a 30 ft flex header in soybeans with a lateral attachment would do a better job of cutting beans than a 20 foot flex without a lateral feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 1:04pm
So I take it the lateral movement is at the point where the head attaches to the throat? So any applicable head would work, correct?
Thanks
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 3:48pm
The front face of the feederhouse is what moves. It stays on the combine. Gleaner header mounting changed big time(taller) in the 97 or 98 model year, so older heads don't fit without changes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 8:31pm
Can you manually tilt a later tilt head to either side? I followed a Gleaner rotor down a state hwy and he had his corn head tilted up to clear bridge bannisters...or so it appeared.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 9:51pm
yes
