R62 lateral tilt need help |
charlesbendal
Joined: 28 Nov 2015 Location: Fryburg, Pa Points: 92 |
Topic: R62 lateral tilt need helpPosted: 19 Oct 2017 at 7:29pm |
We have an R62 with an 800 head and single point hookup. The lateral tilt is not working if you press the button to turn it on the light to show it is on does nothing. If you calibrate the lateral tilt the light flashes on so the bulb is ok. I have both the box with the buttons and the box for under the console from my old combine and if I put those in it acts the same. What does the light not lighting mean?
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Posted: 19 Oct 2017 at 9:23pm |
Does it run off potentiometers? If so if you manipulate them does the resistance change?
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3526 |
Posted: 19 Oct 2017 at 10:25pm |
check the potentiometers - from min to max they need to feed back 1.5 to 4.5 volts - out of range it will not recognize it - does the auto hhc work w/o the lateral tilt? does that light come on and flash ? regular to showing error code/? i.e. 1 the 3 flashes for a 13 error code?
