R-50 combine over head console switch |
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 256 |
Topic: R-50 combine over head console switchPosted: 23 Apr 2018 at 12:43pm |
At the bottom of the tattletale 3 monitor there is a pic of a combine with what looks like the chopper or the cylinder is "highlighted" with a high-low rocker switch directly below it. The op book doesn't say much about it or what that switch controls. Would some one tell this old dummy what it does. Thanks Dave
Amos
Posted: 23 Apr 2018 at 1:07pm |
You switch it to high when you have the chopper drive belt on the high speed pulley and set it to low when on the low speed pulley...if my memory has that correct...
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
Posted: 23 Apr 2018 at 2:10pm |
Like Amos said, it's so the tattletale reads correctly. For instance, if it's set on "high" but you're running the low-speed pulley, the lower speed will trigger the light on the monitor when in reality, everything is working fine.
