Quick attach front loader swap
Jake79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake79 Quote  Post ReplyReply Direct Link To This Post Topic: Quick attach front loader swap
    Posted: 02 Mar 2020 at 7:51pm
I recently purchased a 185 with a loader. It needs a few things done to it, and a good once over. I took the loader off and was wondering if any y'all have swapped from 100 series to D series? Seeing how my 19 has the weights on rear and the 185 will make a way better haying tractor. I think will a little inginuity it can be done. All input is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 8:00pm
Do yourself a favor if you re-mount it on the 185. If it does not have the connectors to brace it back to the rear end, take it easy with that mid-mount as both the torque tube and the wishbone will thank you.
Have seen a few custom fabbed as they did not want to risk breaking the old girl in half.
This page was generated in 0.444 seconds.
