Questions, Wanting a 2600 disc, how big do I need?
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Topic: Questions, Wanting a 2600 disc, how big do I need?
    Posted: 10 Feb 2012 at 10:46am
I'm thinking of buying a bigger 2600 disc. I have a 17ft now, but its way to small for my tractors. I've got two FWA 8070's and a 7080, would the 32 ft 2600 be too big, and are there any in missouri? Would like to be able to pull it in 4th gear slow side on the 8070 PS. How much are 2600 disc's running for, never did have many in our area.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 11:14am
Alot depends on your soil, depth you want to run, etc. I used to pull a 30' disk in our sandy loam soil with a White 2-150 (150 hp 2 wheel drive) tractor and it did not seem to work it any too hard. I think a 32' disk would be fine behind an 8070 here. I did not find any 32'  2600 disks in MO on tractorhouse, ironsearch or fastline. On my small acreage if I was not no tilling I'd hook your 17' disk up to your 200 and have a ball!
Mike_426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike_426 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 11:14am
I pull a jd 230 behind my 8050 mfd 25 foot but no packer its maxed out with the disk... In fourth low side ps .. clay and black marsh where I am BTW ..
Edited by Mike_426 - 10 Feb 2012 at 11:18am
G, 200, 8050 mfd, D17, 195 chainsaw, c-wide front
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 3:43pm
We pull a White 273 24' with our 2 1985 8070's and 1 1980 7080. What years are yours?
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 4:08pm
I have a 21 foot 2600 disc and it is ALL my 7060 wants,
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 4:37pm
At one time I had a 26' wing fold 2600 disc  with remlinger harow behind an 8050 fwa, pulled it in low 5. That was a good match. 32 may be a bit much if you plan to work deep.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 4:44pm
My brother pulls a 25 ft 2500 (lighter and smaller 22" blades) with a 7060 and gets along fine....a 2600 (24" blades) at 25 ft he would NOT pull well, if at all.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 4:44pm
I wouldnt even think of going to the field with anything over a 25 ft with those tractors. The 2600 is a wide spaced disc, and they will plow if you let them in. A 30 ft with big blades on it ,is a good match for the 8550 or 4W305
                                                     IG
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 7:40pm
IG is way right, a 30 plus footer would stop you dead in your tracks.  I have a 22 ft Sunflower and that is all the 7060 or 8030 can handle, the 7080 does good with it but to handle it well you wouldn't want any more.  I would have no doubt in saying the Sunflower is allot more disc than the 2600.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 6:31am
I dont want to get something i cant pull, but in the old brochures it shows those tractors with at least 24ft behind them. Guess its the type of soil you're in.
