Questions on 700 series garden tractors
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Questions on 700 series garden tractors
    Posted: 17 Oct 2011 at 6:21pm
Are the frames the same in the 710-716 garden tractors??  For example, could the 16hp kohler bolt into a 710?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 6:41pm
I think they are.   The 716 that I have came originally with a 16 hp Kohler but it was retrofitted with a 16 hp Briggs.   I know between some of the older engines and the newer engines, commands for example, the height of the base of the engine to the centerline of the driveshaft is a hair different so that's something to doublecheck.  I retrofitted a 23 hp kohler command into a 7117 that had a 17 hp kohler kt17 twin in it, and one of the things that had to be done was to make a mounting plate to raise the engine up a 1/2 to get the driveshaft aligned properly.
Hope that helps.   Otherwise, post something on the simpletractors website.   there is alot of good guys on there.   Once you get on the website, on the far right is a small icon that you have to click on to get to the forum.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 8:04pm
Same frame
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2011 at 6:09am
Thanks for the tip,  Chuck, on the simpletractors website.   I have been looking on there for ages to try and find the discussions and classified sections!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2011 at 8:07am
Kevin, when you go to the home page, there are a series of icons on the top right. They will highlight when you drag the cursor across them. Go to the one marked Clubhouse and click it. This will direct you to a tool bar with sections on it. Drag the sections and each one will have a drop down menu to click on where you wish to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2011 at 8:12am
As far as I can see, the 700 series frames are the same. I've looked at a whole pile of em' at Dales' show this year, and from what I can tell, its the exact same frame. Even the rear bolt on section where the gear box is located and back are the same. In any event, the 700's make awesome work machines. My 716H is a animal especially in the snow removal department. Its unstoppable with its AC Dozer blade and the aggresive ATV rear fatso's for the extra bite. I added a rear weight box, and look out here I come!
Steve@B&B
This page was generated in 0.252 seconds.
