Questions about a Woods belly mower |
littlemarv ![]() Orange Level ![]() Joined: 10 Jun 2013 Location: Wisconsin Points: 1829 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Sep 2017 at 8:46pm |
I'd like to find a Woods belly mower to put on a B.
1. Are they only "finish " mowers, or do they have "rougher" cutting ones? 2. What are the different size decks available? 3.I'm assuming there are special brackets and drive pulleys to each model tractor? 4.What should a guy pay for one, and are there any known issues to look for when buying one, or common problems with them? 5. What's with the left or right discharge? I always thought someday I would have a narrow front CA with a belly mower for mowing up at Pa's. But he has a B sitting there with new rear tires on it, and it hasn't gotten used much since I brought the WD home. Yes, a CA would be more maneuverable with a narrow front and a hand clutch, but the yard is mostly open so the B would be fine. Thoughts/advice appreciated. |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
WC7610 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Sioux City, IA Points: 764 |
I think finish mowers. They have brackets per tractor model but I think you could modify.
A CA would be ideal, don't care how open, when you get in heavy grass/weeds sometimes you need that hand clutch. I had one on a WD, I think a L306? not sure the number is right. Pd $1500 for it and tractor.
Thanks
Most Bad Government has grown out of Too Much Government- Thomas Jefferson |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5108 |
Dad's wide front CA and L306 woods is a good combo. Hand clutch is a huge help when maneuvering around objects or in thick grass. The CA has enough extra power to snap a belt in heavy grass if you push it too hard. It does a very good job mowing.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 85060 |
I have a B with a WOOD... think it is a L59. 60 inch mower. Suppose to be a finish mower. Will cut taller weeds, but you got to keep the belt REAL TIGHT and raise the deck a few inches... A wide front B will turn pretty sharp. Wont spin on a dime, but they do good.
mtanut ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: sandy lake, pa Points: 545 |
For a B, C and CA you need an L59 or L306 a Woods mower with out the L in front of it will spin the wrong way.
I have a 185 Allis, 6060 Allis, Model K gleaner, SMTA ferg 35, ferg 20 (paps first tractor, Allis B (wife's)John Deere 240 skid loader and a bunch of the usual farm stuff.
tbird ![]() Bronze Level ![]() ![]() Joined: 01 Nov 2013 Location: usa Points: 126 |
I have a continental mower on a allis chalmers c, works great for 350, in eastern iowa
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3963 |
Either an L 59 or L306 I've had both on a C and a CA the B has the same power as a C it'll handle either fine. They are finish mowers and are suposed to have end plates on both sides . They are rear discharge. Leave the plates on and they spread the clippings out behind you. I paid $2400 for my L306. I bought it new from the woods dealer. The L 59 came with the locked up CA that I bought. The belt must be kept tight and the hyd lift is useless. The manual lift was an extra $250 when I bought mine. I nolonger use a lift of any kind just a chain to keep it from droping down . TheL59 mows great without guage wheels just suspended from the chain . The L 306 osalatates to much without guage wheels
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
I have a B that I bought with a single center mandrel bladed Woods belly mower. I also bought a G with the same type blade. Both would be rough cut mowers much like any rotary mowers only mounts under the belly. I have never mounted either one. The one for the G has a single gage wheel in the front center. The one for the B does not have gage wheels.
Edited by Dick L - 13 Sep 2017 at 2:29pm |
OK, so do I begin my search for an L59 or an L306, or a 59 or a 306? How wide is a 306?
L306 is 6 ft cut. Only one i am familiar with. Really good mower.
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1270 |
59 is plenty of mower if you do anything taller than a lawn. L models are more popular because that is what the Woods company recommends. (why??? I don't know) The L models need a extra twist in belt that in my opinion shortens the belt life. I prefer the non-L models but, they are harder to find.
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18910 |
Thanks for the replies.
Well, if I HAVE to get another tractor...... The trouble is, the B is sitting there rather forlornly, as I hop on the WD and use it for everything. And, it's grandpa's tractor that he bought brand new, so we would never sell it to make room for a CA. Another hiccup, the B is sitting there with water in the basement. It's not the frost plugs, so I will bring it down this winter and give it an overhaul. The tractor is technically still my dad's, so I get to fix the tractor with some one else's pocketbook! Sweet! |
cdon_FL ![]() Silver Level ![]() ![]() Joined: 15 Aug 2016 Location: NE Florida Points: 116 |
PM Hubnut. He has had B tractors with all possible combinations. Get his take on the issues.
I like the Artsway mower's belt setup more than the Woods belt setup. Artsway has two belts instead of one and easier to keep them on, IMO. I have a CA with Woods mower. My father in law has a B with Arts Way. The hand clutch on my CA is nice feature, but I have used my father in laws B without the hand clutch in light grass and it does OK too.
Chris in NE Florida
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2703 |
The CA and Woods L-306 are a good combination. I've been running this outfit mowing about 3 acres of grass since 1987. Overhauled the engine and replaced 2nd gear at that time and it's still performing well. Does a better job than my more expensive John Deere garden tractor and 60" deck... and more comfortable to ride too.
