Question on an 80 series plow
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Question on an 80 series plow
    Posted: 10 Apr 2011 at 9:40am
On my 80 series mounted plow that I recently acquired, the front coulter beam has been cut off, and the reason why, I believe, is that the beam would interfere with hooking up to the tractor.  Do I have to run without a front coulter?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 9:48am
Maybe it was used on a brand X tractor that the drawbar was in the way??
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 11:01am
No, the plow seems to be just too close to the tractor.  Even on my 180, it seems awfully close.  I don't know how long the original bracket was.  I will be hooking it up again this week, so I will take a photo and post it.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 12:46pm
In my plow bottoms book, all flat coulters mount to the plow beams. On my 2000 plow because the shanks are taller there are coulter beams on the plow shanks.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 2:20pm
On my 4-16 Model 74 3-point plow I use on my One-eighty, the front coutler runs very close to the right 3-point lift arm.  This would cause the plow to plug badly with corn stalk trash.  I removed the front coulter and that eliminated the problem.  No difference in how it plows otherwise with the front coulter off.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 3:08pm
Thanks, guys!
