Question on a D14 head
Madkor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Madkor Quote  Post ReplyReply Direct Link To This Post Topic: Question on a D14 head
    Posted: 09 Apr 2018 at 8:29am
I am replacing the manifold studs. when I pulled the studs antifreeze came out of two of the short stud holes. I assume that's not normal and my head is cracked or somebody put the studs in to deep. If that is normal do you put a sealer on the studs? So just wondering what I should do next. Thanks in advance for your advise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 8:58am
Put goop on the studs and install them. Perfectly normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Madkor Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 9:01am
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 6:17pm
X2 on perfectly normal.  Put some loctite on the studs.  It'll seal long enough, fer the rust to take over...
I think the generator bracket bolts do this, too...
This page was generated in 0.340 seconds.
