Question on a CE engine |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Nov 2009 at 2:23pm |
I have a good crank to put in my CA. The question I have is about the front and rear main seals. This crank has the spiral groove on both diameters. Is there a seal in the kits available that is felt like the original or will I have to speedy sleeve both ends of the crank and use a new style lip seal?
Hartland Farm ![]() Silver Level ![]() ![]() Joined: 13 Sep 2009 Location: Tennessee Points: 86 |
I use the sleeve and have had good luck so far. I have just put the lip seal in and let it leak. All you get is a few drops when you shut it off. If I were building a show tractor I would spent the money on the sleeve.
Joe (TN)
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
I only sleeve the crank end and use the lip seal in the gasket set. The rear seal is a wide cork ring that fits the retainer. I bed the cork ring in RTV to keep it from turning with the crank and seal the OD in the rertainer. I have done 4 125 rebuilds recently but have not enough running time on any to tell if they are going to leak.
