Question for the electricians
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Topic: Question for the electricians
    Posted: 14 Oct 2025 at 6:11pm
Helping a relative do some handy-man stuff in a house they recently bought. House was gutted and rewired in the mid-1990s from what they were told.
Replacing 2 light fixtures in the basement rec room. Currently 2 4' florescent 2 bulb fixtures controlled by 2 (3 way?) switches. The plastic bulb covers have turned yellow and one is cracked.
The problem is when I took off the covers and was getting ready to remove the fixture I thought I would check for live wires to the fixture with my non-contact voltage tester. With the switches off, the lights are off, but my tester still lights up, slightly dimmer than normal, when I hold it close to the wires coming down from the ceiling to the fixture. Flip the breaker off for the room off and the tester light does not light up.
So I understand why I would have power to the fixture and the lights light up with the light switches "on" (duh!) but why would I have power to the fixture with the switches off and the lights do not turn on?
If it makes any difference they are switching to round LED light fixtures.
plummerscarin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 6:23pm
Traveler wire passing from one switch box to the other through the light fixture box?
Lars(wi) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 6:51pm
Sounds like a bit of stray voltage, probably thru the neutral. I have the same issue in my old house, a couple of those round LED fixtures have a very slight illumination when the switch is ‘off’, can’t see it during the daytime, but at night, the fixtures have a ever so slight illumination. Open the cover, disconnect the wires, and the fixture goes totally dark.
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 6:53pm
I don’t know. I took the metal covers that cover the wires/ballast off and tested where the Romex is connected to the fixture wiring.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 9:58pm
normally the power goes thru the switches, then to the light... It is possible to run the power to the LIGHT and then the white wire thru the switches, and back to the box as the ground... see if i can draw a picture.. Not saying this is what you have, but sounds like it..
the BLACK wire from the breaker box goes to the light.. the white wire passes thru the light box, not connected to anything... The light feeds the power side of the first switch.... the two switch terminals on each switch are connected as normal ( the blue wires-- these could be any color in reality).... then the WHITE wire comes off the second switch HOT SIDE and runs back to the breaker box to complete the NEUTRAL side of the circuit..
EDIT... the drawing should say NEUTRAL for the white wire.. not GROUND..
Edited by steve(ill) - 14 Oct 2025 at 10:15pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 10:20pm
normally the light box would have ONE Romex wire inside... Black inlet and white neutral.. one on each terminal..( see below)... If you have TWO ROMEX wires, and the whites are connected together, and NOT on the light terminals..and you have a BLACK WIRE on both light terminals... then you might have the above drawing.
Edited by steve(ill) - 14 Oct 2025 at 10:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 7:45am
From what I remember, I won't be back there until next weekend, is one 2' chunk of Romex came out of each junction box for each fixture, 2 wires attached to the fixture wires and one to ground on the fixture. Nothing that I can see that the wires are jumpered to another fixture.
If there is some sort of stray voltage would it be better to get traditional light fixtures with bulbs instead of an intergraded LED fixture?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 8:19am
Yes, the traditional bulbs would eliminate that slight illumination, better yet eliminate LED whenever practical. We don’t use any in ‘living areas’ of our home, just laundry room, or closets,etc. LED can be more damaging to eyeball receptors, neurological function, sleep patterns, etc., than even fluorescent bulbs. The ‘healthiest’ light, other than natural sunlight, is incandescent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 8:46am
?????  I have used nothing but screw in LED bulbs for the past 12 years in every room of the house, garage, shop and barn... Have never had a problem with stray voltage or glow... If your light switch kills the power on the line running to the light fixture,  i dont see how your get residual or stray voltage.. Now if your house is wired with the HOT WIRE directly to the bulb and you have stray voltage to the white or ground wire in the box, that might be different... But it is abnormal to wire HOT to the light box.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 1:28pm
there's NO such thing as a 'normal' 3 way, 2 light  circuit !!! At least 4 different ways to physically 'wire' them... 5 if YOU can figure out HOW the 2 hallway-stairs are wired at my place !!!! been here 40 years, gave up after 13 ,trying......
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 9:14pm
Maybe, you the infamous’ Chicago 3-way’ wiring?
DaveKamp View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2025 at 7:16am
Non-contact voltage testers do not actually indicate presence of line voltage.  They're basically extremely-low-frequency radio receivers, tuned to be resonant over the range of 50-60hz, and the tiny 'tab' at the end is nothing more than a short piece of wire connected to a high-gain transistor and a peizoelectric tap connected to a Field Effect Transistor.  This is what's called a capacitively-coupled electrostatic sensor.
In an environment of electronically 'noisy' electronics, these gadgets will will give you false indications just as often as correct, hence, they are not diagnostic tools in ANY way, they are merely 'suggestors' of a circumstance that requires further investigation.  If you live near a broadcast radio tower, you'll find that EVERY wire in your house will indicate 'live'.  If you lay out 50 feet of wire on the ground, underneath an overhead distribution line, IT will test 'live', as a result of electromagnetic induction.  When you see a flicker, get a real meter, set it to an appropriate range, and probe the wires properly.
Unexpected voltages appear as a result of many things- one of them is switches with internal illumination.  The power for internal illumination comes from a small amount of power to be 'leaked' through the illumination, to the load, when switch is off.  Many other electronic devices, like your 'smart' TV, the countertop icemaker, etc, are essentially always 'on', even when you have them functionally 'off'.  Their power supplies generate noise which leaks backwards into the supply wiring, radiating like a transmitting antenna into all the other wiring in the house...
This page was generated in 0.223 seconds.
