Question Dr.Allis
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Topic: Question Dr.Allis
    Posted: 27 Apr 2010 at 8:53pm
We have an xt 190 series 3 with 200 hrs on overhaul and when you start pulling it down it starts smoking like a freight train and falls flat on it's face. It sounds like it's flooding out like a gasser when you pull out the choke. We put new injectors in when we overhauled it.When it's idling the fumes out the exhaust will choke a horse. would it be the pump or bad turbo? Thanks, Mike.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:34pm
How's the air filter?  Could be starving for air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:39pm
So it's done this for 200 hrs????? sounds like turbo or bad air leak, but the smoke at an idle isn't that.... a boost gauge reading would tell us something.....XT series 3 should have an AirResearch turbo.?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:37pm
what is the timing - sounds retarded , bump it up 2 degrees at a time.  Also check the intake manifold for a plug missing thus dumping boost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 9:24pm
Thanks guys just got in from drilling beans. when it rains I'll put a gauge on it and see what we have, and then play with the timing. Could they have put the wrong tips on the injectors? Because it didn't do this before we overhauled it. Thanks again to everybody.
