Putting the AC sub soiler to use
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Putting the AC sub soiler to use
    Posted: 11 Dec 2010 at 11:11am
It is amazing what you can still do with old AC equipment. We have a hedge row out at our farm and several ditches with trees growing in them. We decided that we needed to buy a sub-soiler to bust the roots that were growing out into the field. I started down a hedgerow pulling with my WD,[ My WD has D-17 head and who knows what all else of a WD45 engine in it],so it has the power to pull pretty deep. You can't believe the roots that pulled up. I set it as deep as it would pull it, I pulled up 3" diameter roots that was going out into the field. I went around a grove of trees where there once was an old house. I hooked onto something that stopped the tractor and killed it. When I tried to raise the subsoiler, it wouldn't come up. I thought for an instance that I may have caught up on  an old water line or something. I backed up and hit it again and the biggest old root you could imagine came up, I know it was more than 3" diameter. Surely we will see a difference this next spring, especially if we get a dry year. I  believe I will do this every Fall now.  Dave.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 4:02pm
sounds like good fun!! Darrel
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 4:16pm
To bad your "A" doesn't have a snap coupler. That root would have come out like all the rest.
