Purchasing a Trailer-Is this a good deal?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Purchasing a Trailer-Is this a good deal?
    Posted: 31 Oct 2010 at 7:47am
Hi everyone,
I am looking at a 2001 PJ flat deck 30' 20000 lb trailer with duals that appearance-wise looks to be in good shape.  It comes with (9) new tires and brakes along with 8000# winch & 100' of cable.  It is also set up with three ramps.  The guy is asking $6300.
Is this in the ballpark of what it is worth?  Too much??
Thanks in advance for the help,
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
smuggler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 7:49am
sounds like a pretty fair price to me are  the tires radials?
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 8:37am
Well, I bought a new 27 foot tilt deck Corn Pro in january for about that. If that trailer fills your needs I'd say go for it.
Remember that at 20,000# you will be exceeding the towing capacity of all of the pickup trucks that I can think of and the actual load capacity of that trailer will be around 12,000 pounds give or a take a couple thousand.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 8:48am
If you want to find out if any problems with it , have it DOT inspected to see if it meets all the rules of the road.
 Kid was going to buy a larger trailer from dealer and was wondering what i thought of it , I looked at it and it was not worth what he put down on it. Dealer said it was DOT stickered already so did not need inspection.   Told them I wanted current (up to date inspection NEW) , it did not pass , needed as much work as price of trailer to pass.
 refunded deposit , grudgingly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 8:56am
Inspect the spring seats and equalizer areas closely, I am in the process of replacing the rockers on mine as they are all broken up and appear to have been for some time but I failed to crawl under and look.  Look at the cross member welds and if the flooring has been replaced for any boltings that have compromised the cross members.  Otherwise the price sounds good for the weight and style especially with new tires bias or radial.
