Pulls to the left
Stoges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stoges Quote  Post ReplyReply Direct Link To This Post Topic: Pulls to the left
    Posted: 5 hours 24 minutes ago at 3:06am
Just about have all the kinks ironed out with y WD45 except when the front wheels start to dance she pulls to the left. I weight the front but on a good track she still gets light in the front. I have used the right brake to try to keep it straight but that costs you distance. Any advice on how to get power to the left.. Thanks Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 49 minutes ago at 6:41am
First check to see that everything is equal. Tire pressure, tread wear, weight on each tire, tread width, ect. If it still pulls to the left, move your drawbar to the right a tiny bit. A little will make a big difference, like 1/16" at a time.  You can't check, but the spider gear pin in the differential could be galled a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 46 minutes ago at 6:44am
Your big butt in the right-side seat could well be causing it. I always hung (when I could) 200 lbs on the left side to make up for my big butt. When this wasn't possible, all the weights on the nose were on the left side.
This page was generated in 0.111 seconds.
