Pulling year rules
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Topic: Pulling year rules
    Posted: 21 Mar 2010 at 8:47pm
If rules say 1957 and older or production models that started in 1957 should a series 4 17 be allowed to pull? The d17 was introduced in the fall of 57  My interpretation would be yes it could pull but everybodys different. What are your thoughts?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 8:54pm
I would say so.  As far as I know, a 4 has no advantage over the older ones.  I assume the hyd are going to be pulled for weight anway.  What other differences would there be that someone could claim as an advantage?
AaronSEIA
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 1:56pm
Thats the way it is in the two clubs I pull with. Dairyland and Comunity. Just think of all those olivers that also fit this rule.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 2:06pm
Any of the pulls i go to in the SWOH and SEIN the year rule applies th the same model. I can pull my '56 WD45 in a pull that has a year limit of '55 because the model was produced before the cut off. As far as the D-17 goes i have a '59 I can pull it in a '57 year pull because its the same series that was produced in the year range. A series 2 3 or 4 couldnt pull because they changed the series desigination. I dont know why that matters really but thats the way it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 4:57pm
A Series IV has more powertrain HP losses than a Series I,II,or III due to the hydraulic pump ran off the flywheel via a hollow quill shaft as mentioned.  I don't remember how the shaft is supported on the outside of the torque tube where it directly drives the external hydraulic pump but it might not be quite as easy as pulling the pump off and putting a plate over it.  You'd probably have to go in the torque tube and remove the whole drive mechanism to do it right.  Much cheaper and probably better to use an earlier D17 as a puller and save the Series IV's for work.  My 2 cents...Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
This page was generated in 0.089 seconds.
