Pulling Scale Problems
Ag_F150 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ag_F150 Quote  Post ReplyReply Direct Link To This Post Topic: Pulling Scale Problems
    Posted: 20 Jan 2016 at 9:10am
My pulling club is having trailer issues with our mobile pulling scale. Right now we have a home made scale and trailer. The trailer is not road worthy anymore. We are exploring other scale options... building a new lighter one, buying a used scale, trailer combo. If anyone has any ideas to share how their pulling club scale is set up, or any suggestions for what we could do, I would like to hear them. Thanks in advanced!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 10:54am
club i belong to sets scale on upper end of sled when traveling.  unchain and remove with a loader, then set back on when pull is done.  if your sled is traveling, you would only have 1 item to transport instead of 2.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 6:49pm
our club uses a pintle hitch semi to pull the sled.the scale sits on back,over the fifth wheel,on a taller bracket,unloads with any kind of hoist or loader.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 9:01pm
The club I pull in uses a set of flat digital scales with a LED readout that can be read from the tractor seat. They are very light and much safer, since they are flat. Probably quite expensive, but easy to use and very safe!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ag_F150 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2016 at 6:36am
WF owner: Do you have a picture of the setup? Also, do you need equipment to lift them? What are they transported on? Who manufactures it?
This page was generated in 0.060 seconds.
