Pulling my Grandpas 200 questions
Jacob Mishler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob Mishler Quote  Post ReplyReply Direct Link To This Post Topic: Pulling my Grandpas 200 questions
    Posted: 8 hours 55 minutes ago at 10:52am
Howdy, I am looking to pull my grandfathers 200 AC tomorrow for the 2nd time since his passing. He bought the 200 brand new and we have countless photos and trophies of it around the house from the old pulling days. Anyway I am looking for any suggestions on how to improve its pulling. Or maybe ideas of what I could be doing wrong, as I can no longer ask him all these questions I have. I will be pulling it in the 10,000 pound turbo open class. I am almost certain he pulled it in 2nd gear high? If I remember correctly I get the tractor up to 3/4 throttle, and then full throttle once I am on the move? 10psi in the rear tires? I am hooking up to the stock location of the rear bar, not sure the exact name for that. Seems like it hooks very low to the ground? Would that make much of a difference? It has an upgraded injection pump, and a newer turbo. It’s about time for a new clutch but I will get everything out of this one I can. Any suggestions or recommendations are appreciate. It’s means a lot to me to pull this tractor at all. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 38 minutes ago at 11:09am
Probably 2nd gear high side. I have no idea what size rubber or engine HP, but 2nd high works for me. 10 psi on the tires sounds low to be, but again I'm not there looking at your tires or the kind of dirt you are pulling on. You ideally want your drawbar as high (20 inches?) as the rules allow and as short (18 inches from the rear axle center) as it can be as per the rules. Drawbar height and length is of HUGE importance !!!!    Make sure your foot clutch pedal has 2 inches of free-play in it. Adjust the clevis under the hood on the left side.
Edited by DrAllis - 8 hours 37 minutes ago at 11:10am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 29 minutes ago at 11:18am
Sometimes the biggest variable in pulling is the nut behind the steering wheel...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob Mishler Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 12 minutes ago at 2:35pm
Thank you sir I have put my draw bar as high as I can which is 18inches up, and back as far as I can. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 20 minutes ago at 3:27pm
YOU WANT THE DRAWBAR AS SHORT AS YOU CAN GET IT !!!!!!!
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 24 minutes ago at 4:23pm
Bolt your clevis tight with the largest bolt that goes thru it and the drawbar. Take up any play with washers in between. We had a hitch made from steel plate that bolted to the top of the drawbar with a hole cut large enough for the sleds hook.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 52 minutes ago at 4:55pm
All of those Cat 2 hitch type tractors I would remove the drawbar itself, turn the crosspiece around so it curves forward and like Dan said, bolt a plate on top (or bottom) of the crosspiece and get it shimmed to the max height allowed, which is usually 20 inches. Get those four bolts tight and don't jerk the sled !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 31 minutes ago at 5:16pm
Does it have a gated Power Director lever or the push down to shift it?
