pulling history question AC
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: pulling history question AC
    Posted: 01 Dec 2013 at 6:16am
The original Quad Squad of AC,s were Al Kock,John Lancaster,Brad Howell and Norm Green, but Green dropped out and moved away but was considered an original member he had the first with 4 turbos to run cause his D21 was broke down and they rebuilt it to the 4 turbo setup to get more power; these four guys worked together and knew each others setups so they wouldn't waste time duplicating the same ; the article of the NTPA from 85 reads that it really turned heads seein it run
Edited by DougG - 01 Dec 2013 at 6:43am
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2013 at 8:29am
That photo is of the Imposter - Brabec's D21 with 8050 hoods.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2013 at 3:49am
I have an NTPA magizine covering this subject ill look it up tonight
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 6:59pm
Brad Howell also used two in-line Bosch injection pumps for a while. Reliability seemed to be an issue, and I think he went back to one or went with a Hypermax Sigma pump.
BRYAN H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BRYAN H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 11:00am
AC 7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 10:37am
Brad Howell was one of the quad squad from Green town IN
AS185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AS185 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 9:51am
Not ntpa but wasn't noble the founder of quads in a 220?
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 9:50am
Koch and Able where the other two I believe.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 8:28am
there were 4 guys who ran quad chargers in the NTPA curcuit many years ago - I think it was Max Simpson as one John Lancaster two - Slow day at work , ha - who were the other two runing at the time ?  One had a car dealership, can't remember the other canpaigner...
