Pulling gears
Message Reverse Sort Order
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Topic: Pulling gears
    Posted: 13 Sep 2015 at 8:53pm
I ran it with a set of speed up input gears.   MACK
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 8:11am
Gear count is top 29 T bottom 21 T. about half way between 2nd and 3rd. Goes in place of 2nd.   MACK
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 7:57am
1.38 : 1 would mean it was 38% slower than direct drive - 8th gear. 7th gear is about 20% slower than 8th. You would be somewhere between 6th and 7th gear I think.
Mack, I assume that ratio is with a standard input gear set or is that the ratio of just the gear pair you are selling. That's why I was asking for the tooth counts.
Edited by O.P.S. Heads - 13 Sep 2015 at 7:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 5:10am
That's what I'm wondering,, where do they fit and how much faster
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 1:41am
Do you have the tooth counts for the top and bottom gears? Also, is this made to fit in the second or third gear spot in the transmission?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 9:47pm
Found a set of gears I took out several years ago. They are 1.3809-1 for 180-200. 350.00 + shipping.  660 663 9173   MACK
